Noise from Steering
Nvd
00 Disco SII,
I'm getting a noise from steering wheel when I turn it fast. Kind of sounds as if something is/has not been lube properly.
Has anyone else experienced this?
Thanks
First, have you checked the fluid level? Also do you have ACE on your DII? If so, it may be the ACE system making noise, not the steering.
Nvd
Level is good and No ACE installed.
I'm thinking its the connections in the engine bay, their showing signs of rust/corrosion. I tried sprayinig white lithium grease on them, but the sound came back. I'm trying to catch this before it gets real pricey.
Thanks Joey
Try some lucas transmission fix... I know transmission, but since the PS on a Rover takes transmission fluid.
D
discoinjapan
Wheel bearing or CV, but sometimes it could be the susp.
