T
Tango6
I have a 2000 Disco that makes an annoying "sloshing" sound in the ventilation system. At least that is where it seems like it is coming from. Heat and AC both work fine. Noise seems to be random and you can hear it best when starting off and turning simultaneously.
Also, I did a search but didn't find any info on this: My right rear seems to drop randomly, ie loses air pressure when parked. After starting it pumps back up and is fine, although on saturday it went down while driving and didn't immediately pump back up. Aftre sitting for about an hour I started it up and it pumped back up. I am hearing the compressor run more. Where should I start to look and how much money am I looking at if it is worst case?
Don't misconstrue the last comment as being negative, I really like the Disco, just curious.
