Non OEM Hitch Choices
BazLR3
Hi All. I was wondering if anyone installed a hitch other than OEM. The cost is reasonable at around $150-170, they attach to the frame rails. How do they look from the back of the truck? Are there any pros/cons to installing a non OEM hitch?
Thanks.
morrisdl
CONS - If you off road, you will lose some rear departure angle clearance. You will still need the LR towing electrics to work correctly. Youll have an extra $200 burning a hole in you pocket ;-)
gtc
I think RoverCity.com sells the OEM hitch for ~250USD (NEW) and they had free shipping a year or so ago...
Roverine
Thanks.
A am curious about the profile of the non-OEM hitch also. While it looks like it might slightly decrease the angle of departure off-road, it sure looks like it would not hang down as much as the OEM version for regular towing, which has been a problem for me. I can't clear the crown of my drive at the curb without dragging the OEM hitch unless I raise to off-road height.
foofighter
i've seen Curt hitches and they go for ~$130+35 shipping on the web.
http://www.disco3.co.uk/forum/topic39266.html
beantmt
Dang
That Curt hitch is pretty cool. I was hoping it would improve the tongue weight situation, but it only increases it to 600lbs. with a more limited towing capacity of 6,000lbs.
BazLR3
Thats exactly what I was looking for guys. I am also considering the OEM if I can fit the tow ball size I am looking for. I guess I will need to order the wiring regardless of the hitch type and I assume the OEM part is best for this. Do they come with a 4, 5 or 7 pin? My trailer has 5 pins, one extra to release the trailer brakes.
MArsel
