LR4 Trailer Hitch Service / Rebuild
Longtrail
Ann Arbor
Tribe,
Update for this project:
I ordered the part needed to proceed, the "tow hitch ratchet cog repair kit" from the only supplier I can seem to find, which is powerfuluk:
https://www.powerfuluk.com/products...pGqJoqWeYpQBNBfRlZuMfvabALB59IhGT9KCwiIdZxHLN
Unfortunately, this is yet another part powerfuluk refused to sell to me purchase because it appears they don't like me, and in any case won't sell to me (I tried this time direct sales through eBay rather than their website, which they insisted I use the last time, but they this time again denied my purchase and after taking my money, refunded the charges in full; screenshot attached).
So yet another terrible customer experience and I simply cannot recommend https://www.powerfuluk.com/ to anyone and am even a bit ashamed I had to go to them in the first place (after my last run-in with them). Perhaps they simply hate Americans or sending things to America.... Or just me.
Funny how business works, or doesn't.
Since www.powerfuluk.com is the only supplier I know of who make this part, my OEM trailer hitch rebuild project is now officially over (unless someone has this part or knows of where I could get it).
And as @powershift recommends - I will soon be in the market for an improved aftermarket hitch receiver - suggestions most welcome!
So on the other hand...perhaps I should instead thank www.powerfuluk.com for being so unhelpful so I could ditch some stuff which I could get better elsewhere in the end!
I provided a link above; in the video they mentioned where they found that part:
Perhaps give this a go?
Land Rover Joe
Oxford
On the green part, there's a roll pin you have to push out. Then the green part slides off.
After we screwed this up - I now know what you (@Rover Range ) mean and that would have been a far, far easier solution.
The powerfuluk videos demonstrate how to push that roll pin out with an awl punch.
Easier (and cheaper!) than what we are doing now....
Land Rover Joe
Oxford
I wrote them!
Many thanks @Longtrail
I think their part
"LR Hitch Receiver Lock Alternative Replacement"​
Is exactly what I need (and maybe even an upgrade)!
powershift
Nevada
Tribe,
Unfortunately, this is yet another part powerfuluk refused my purchase because it appears they don't like me, and in any case won't sell to me (I tried this time direct sales through eBay rather than their website, which they insisted I use the last time, but they this time again denied my purchase and after taking my money, refunded the charges in full; screenshot attached).
UHaul has quality towing hitches and receivers, I've bought from them and would go back. For my hitch I had the idea to upgrade so I can get the 700 lbs tongue weight instead of the lower 550# that the manual refers to. But the reality is I don't have a trailer now so I haven't researched brands or the type I need. I've seen the hitch that looks like a ****** repructive organ that is common in Europe, but don't want that.
I looked at my rig the other day and found it doesn't have trailer wiring. Did your rig come with trailer wiring or did you add it? Is there a kit to get it wired?
Land Rover Joe
Oxford
Thanks and the truck didn't come with the wiring (which is strange to me) but I bought the NAS (USA) version and had that installed at the dealership when it was delivered (with all these other things...to include this OEM Trailer Hitch).
Atlantic British sells an aftermarket for my truck (that is the 2010 LR4) which is similar to my OEM -
I snapped a photo of what that plug (on the left) looks like - attached below.
A couple words / comments. First, there are different types of plugs out there (for example NAS versus EU versus NATO). Make sure you are getting the plug you need. Second, the frame has two mounting points for wiring - right and left (see round hole on the right of the photo). My understanding is that you can choose either. I had mine installed on the left arbitrarily (I don't know advantages / disadvantages). Finally, my experience is the rear-end gets a lot of road grime, water, dust, etc. This is doubly so with the aftermarket steel bumper I installed in 2015 - and we just stripped / repainted everything (which is why it looks nice here, but was really corroded previously, especially the frame/bumper). This is problematic because as you can see by the hanging wire conduit there (still are working but will need to secure everything better)...a lot of these wires and hoses have a tendency to get beat up. So some things to keep in mind depending upon your needs and build.
Hope that helps!
powershift
Nevada
Hope that helps!
Nice that they have a plug to connect into. I thought the worst, splicing wires lol.
Northern
Halifax, NS
Mine lost its hitch sometime before I bought it. I found one in an LR4 at the junkyard and cut the whole rear bumper bar off to bring it home and make it easier to extract.
I removed the roll pin holding the lock on, then the two SHCS holding the orange plastic ratcheting cover on, and slid the splined rod and spring out.
You can remove the chrome cap on the other side and slide the splined rod out that way, but the junkyard decided the locking cap and that end of the splined rod was the perfect place for a jackstand, so the end of the rod is bent and I didn't want to try to force it out.
I soaked the inside and big retaining pin with 50/50 Acetone ATF for a bit, and then used a brass drift and hammer to drive the pin back into the hitch to release it from the bumper.
Removing the pin from the hitch afterward took the longest. It was very seized and needed a lot of soaking in lube and working the pin in/out to free it up over the course of 3 evenings or so, maybe a handful of minutes per night.
I used some vise grips on the splined shaft to get leverage (I'm sure if you put too much force on it, it would shear off), used some prying tools to get leverage on the inside of the pin when there was a gap on the inside, and the brass drift/hammer to work it back in.
Once it and its spring are out, there will be a small ball bearing loose, and the top pin can be pushed out, as well as its spring. You don't need to touch this beforehand.
Now that I have it apart with all replacement lock bits in hand, I'm thinking about just going with the Safari Gard Hippo Hitch, or making a similar setup that I can leave installed and not worry about departure angle, storage, or how sketchy it is while hauling a car trailer for long distances.
Evelyn
