OEM brakes
clieman
Does anyone know who the supplier is of genuine brake pads and rotors is for the systems on an 01 disco II? I have the three lights and everyone I talk to says I gotta use genuine pads (I got aftermarket on there now and they squeek like hell). Thanks.
The three amigos normally have nothing to do with the type of pads... but hey what do I know.
Squeak is normal on any metallic brake pad... go semi-metallic or standard.
If you want brakes. Contact Nathan www.discountbritishparts.com
1sparrow
I use Lubro Moly LM 508 anti- seize compound on the back bearing surface of the pads. Also on the caliper rails. LM 508 is high temp. and copper color. It has a brake pad image on the tube. Easy find at Import parts store . ( German / Euro )
Dennis
