OME spring install
crash
Getting ready to install new rear springs. They are the Heavy Load part # 2762 springs.
Which end goes up??? The more tightly wound end up or vice versa?
It may not even make a difference!
C
It doesn't matter. What are you installing in the front? Make sure you put the coils marked "A" on the drivers side.
Who's shocks are you using?
crash
They are OME springs. I think have the front ones figured out.
C
crash
Mike
I am sticking with the relatively new billsteins for now. Apparently I am within their operating range with the slightly taller springs.
The truck had the HD rover springs installed 2 years ago when a winch was mounted o nthe truck. The rear ones are not up to the load I carry so I picked up a set of the OME springs.
Hopefully the install goes well this weekend.
C
If, when you are done, if the truck is not level, get back to me and I'll give you some pointers.
