Problem with lights
Kinz384
Ok. My low beam lights just quit working. Both at same time. I had just replaced one about 6 months ago. So I wouldn't think both went out at same exact time.
High beams work & running lights work. I checked fuse #62. Book says is for low beams & it's fine.
Any suggestions on what to check.
I'm 2 hrs away from closest LR dealer so hard to get to
Thanks for any help
Oh it's 2005 se. W/ Halogen lights
Rubber Cow
Start with replacing the bulbs...I know it sounds obvious but...that's where I'd start.
Then the relay.
Then the main switch.
