Rear ac f22 keeps blowing
bbjj
US
Recently I I had passanger side front and rear soaked with water due to heavy rain and sunroof drain clogged.. Anyways got that problem fix, after putting everything back in its place I noticed that my rear ac vents not blowing air. I checked fuse and it was blown. Kept putting fuse and it kept blowing. I checked kick panels to see if maybe I cut or pinched a wire, everything looked OK. I checked rear blower motor 12v, working. I unplugged the rear blower motor and put new fuse and it blew it. I want to tackle this myself before spending tons of money to have someone fix it.. Has anyone had a similar issue? Triple digits here in Texas. I spent all day trying to figure out, today was 104 degrees [emoji91]
Thanks in advance guys.
Sent from my G8441 using Tapatalk
Rubber Cow
Did you check all of the wiring below the front passenger seat footwell carpeting?
Shorts are very common.
bbjj
US
I did, but all looked ok, i will recheck later this evening pull everything back.
bbjj
US
Update... Still popping fuses and I refuse to take to shop.
Sent from my moto g(6) play using Tapatalk
tragic1
