Rear Brake 2000 Disco
A
amvauto
Ok, I just noticed that my brake lights are not working on my 2000 Disco 2...I had a problem a few weeks ago where I was unable to get park, I was able to open the middle console and press the button that releases the shifter out of park. Other than that the brakes work fine as does everything else...I checked the fuses, nothing wrong, the running night lights for the front and back work...but the brakes nothing...so I heard it could be the brake "switch" or something else...what are the options and what is the cheapest easiest way for me to fix this...I am trying to sell my rover asap...please help
You are correct on the brake switch... it is bad. around $20 IIRC, contact Nathan at http://www.discountbritishparts.com/
502-396-7274
He will get the part to you cheap and fast. Just tell him Joey from Land Rover World Forums sent you.
A
amvauto
Hi Thanks, just changed it and still not working....what else could it be...how can I tell if it is actually the switch?
You can ohm the switch out.... do you have a multimeter?
It will either be the switch or a bad wire, I can't remember a fuse that controls just the rear brakes... but hey I can't remember everything.
tragic1
