Rear break lights not working
S
sami44
Hi,
I have a 96 discovery with 140K/ml on the clock. I bought it recently and I’m working on it for off road use.
The read break lights don’t work when applying break. Every thing else works signal lights , fog light and reveres.
I checked the fuse
Changed the bulb (the one with 5W/21W)
I checked the sensor in the break paddle
Nothing .
Where should I start so I can pin point the problem
Moose
Make sure the housing isn't loose. On mine, the bulbs have to be re-adjusted in the housing every so often, or the brake lights will fail. Do you have a functional third brake light (the one in the door)? That will help people help immensely.
S
sami44
It worked
I just hade to start the car!
For some reason after changing the light when pressing on the break paddle it wont work but after I started the car it began working.
MrRodgers
