rear wiper fluid head not working
D
djbensonchad
I have a 1999 discovery and my spraying head on the rear window has somehow stopped working, just wondering if anyone has had a similar problem, and where i should look to solve this problem.
yep, the one way check valve in the engine compartment has gone bad... $5 at the dealer
D
djbensonchad
where is this valve located and what does it look like?
it would be right behind the washer fluid container... it is a small round thing about the size of a Sub C battery
D
djbensonchad
Thanks for you help I'll check it out tonight. one final question, Is it hard to remove?
Nope....took me about 10 minutes to change mine... only took that long because I had never done it before... I could do it now in about 3 minutes or less.
strally
