62Sunbeam
How do I reset the codes on my 95 D1?
I've replaced the O2 Sensors as indicated by the codes and now I would like to reset the code box.
This is what I found on another site and I don't know what the "Serial Link Mating Plug" is
and I don't want to fry anything delicate.
Here is how you clear codes once you've read them and addressed the faults:
1. Switch ignition on.
2. Disconnect serial link mating plug, wait 5 seconds, then reconnect.
3. Switch ignition off and wait for main relay (located under the passenger seat in Range Rovers) to drop out.
4. Switch ignition on. The display should now be reset. If there are other faults, the next one will be displayed. Otherwise the display will be black.
Thanks
Eric
Thanks
Eric
