RRC looses power , Need help please
adventurer
Hello all, my 3.9 i RRC looses power when trying to take off on high range 1st gear and even on 3rd gear low range it dose not rev on a tiny hilly area and also on small area of sand it dose the same , but on paved road its very fast car and faster than any other 3.9 RRC, need help to know whats wrong :confused:
How many miles.... last tune up and what was done?
adventurer
i rebuild the engine , changed all parts except pistons and crank , and changed the 3.9 camshaft with 4.2 camshaft , new coil and 8mm spark plug wires , new clutch and all its tools and new low range chain , i did all this because it was loosing power but still the same problem ..... its done 2000km since the engine was rebuild
Sounds like possibly a fuel issue, but could be the distributor.
If it is an older distributor or still original factory, then it may be worn out... the do tend to get old like anything else.
Paul p
