Serpertine Belt
Taytum98
whats up my rover buddys, had a question for you. Installed new serpentine belt on the rover. New belt fitted good. When i started up every morning now i hear a small whispering tone close to the belt and fan. Screws are on tight, and i don't see anything loose. When i drive off i can hear the noise while im driving for about 20min. Stop at a light or stop some where park and start it up again, and the noise is gone. Is it because of the new belt? Any feed-backs thanks!!!! 99disco1sd,118,000miles
ngv151515
i would recheck every bolt and nut also check if aling correctly with all the pulleys
At your mileage, you should have replaced both idler pullies as well as the belt tensioner, if it is getting weal, or the tensioner pulley. All 3 are know to fail.
Taytum98
Hi mike, so if i replace the tensioner and the idler pullies will the noise stop and how serious is this if i decide not to replace them right now? Thanks for the feed-back.
Taytum98
whats up guys, my father told me to change the belt again. It might be the belt. So i change out the belt with a new one. Problem solved no squeaking noise in the belt anymore.Sweet!!! Thanks for all the feed-back, and advice!!!!! 99 disco1sd.
JoeMazzio
Hi Taytum,
I would still look into changing the tensioner and the 2 pulleys. Just to be safe.
MrRodgers
