Sick D2 V8
R
robertofollia
Hi, again, almost third time with this... well, thing
Vehicle: D2, Bosch engine, 4.0, XA chassis number, SALLTGM28XA901101
Problems before: Low power, condenser fan on whenever stationary (A/C was always off) and not such a smooth engine -but quite smooth-.
Repair: Dismantle MAF, change for another (2nd hand but assured to be OK), clean housing, assemble and test.
Test results: Engine not smooth at all, fluctuating idle, erratic and rough idle
Procedure: Cleal old MAF, assemble and test. REsults: Idle even worse after cleaning, rough running.
Testbook results:
P0150 and P0130- O2 sensors
P0171 Adaptative fuel mixture control Bank 1
P0174 Adaptative fuel mixture control Bank 2
too lean!
MAF error according to T4, I did not write it down correctly, if it was p0120, or p1202 or p0122.
Waiting forthe Actron scanner to reach me
After erasing faults, and performing a test drive:
-Erratic and very very very rough idle (from 750/1000 rpm to nearly stalling). After 5 minutes it stabilised, but accelerating hard in neutral and letting the gas pedal return to rest position it nearly stalled.
-So, now it is not lean, the A/C condensor fan does not run continuosly when stationary...
-Not usual exhaust smell (but not as rotting eggs yet).
-MAF? O2? injector? Pump? All them?
Any help (apart from setting my Rover on fire) would be greatly appreciated
Thank you very much and regards
Robert
1992 LR Santana 88" petrol (healthy)
1995 RRClassic 300 Tdi (better than ever)
1999 D2 V8 petrol (sick)
2004 D2 Td5 diesel (boringly reliable so far)
D
discoinjapan
You may need a new TPS(potentionmeter) or a Idle control valve.
I agree with Discoinjapan.... sounds like the TPS
SulliMtn
