Soggy Socks!
D
dry_fly
And another issues pops up...
I have found that on the front passenger side (US Right side) under my rubber floor mat the carpet is soaked & quite stinky! My 03 disco has been sitting for a few days in the drive way while out on business travels... the car was completely sealed windows & Moon Roof, but somehow it got wet under the floor mat. What puzzles me is the carpet is only wet back by the seat & not up under the dash? I read a past thread with a similar problem, but was currious if anyone thought this could be from the mentioned AC drain or Moon roof Drain? I'll check the rubber ******* ( he he he I got to say ******:)) as Joey suggested... but might anyone know of a leak somewhere else? It is really strange since it is up by the seat? With all kinds of stuff goin wrong with this think... it might be time to off load it... anyone interested in a B. Gray 03 SE with 50K?
Many Thanks!
DF
F
fbrems
It this is the only issue what went wrong with your Disco, consider yourself as a very happy person. Well, remove the carpet, let it dry out for a while and if it drips somewhere it is mostly from the cooling system as previously highlighted or from the AC condenser drain. Not much else has to do with water under you dashboard.
D
dry_fly
so you don't think it could be a leak in the windshield seal?
D
dry_fly
found the *******! they leaked.. hope it works! thanks for your help gents!
They leaked, or were they full of water and you drained them?
D
dry_fly
they were full of water & drained.
So far some rain & dry floorboards!
thx!
D
dry_fly
Joey,iStill have h2o under the mats... Any other suggestions?
I'm seeing if I can release a clog again?
thx!
DF
It may also be the windshield leaking... or the sunroof drains, but normally under the mats is the A/C drains... did you drain both sides?
Tumbler
