Stability Control & HDC Not available. Gear Box Fault. Relay Clicking on a L494.
EdwardRRS
Hollywood, Florida
Relay Clicking on the Passenger Cargo Side. (Stops after 20 seconds) Stability Control & HDC Not available. Gear Box Fault.
For the past 2 weeks. The following Happened in the morning, or if the car has been sitting for a while; About two or three hours+. Relay Clicking sound in the Passenger Cargo Fuse Box Side of Range Rover Sport L494.
Some codes Readings: U0402-92 Invalid data received from transmission failure.
U 3003-17 (2E) Battery Voltage - General Electrical Failure- Circuit Voltage Above Threshold (Note the battery is new) No ON/Stop Battery.
U0001-81 (2E) High-Speed CAN Communication bus
U0028-87 (2E) Vehicle Communication Bus A
B1412-96 (AF) Quiescent Relay Box Component Failure (This Fault is over a year old)
Loveandhatemylr4
North Yorkshire
Hi mate, did you figure out what it was? I’ve a 2010 discovery 4 hse tdv6, just this morning I’ve had the exact same message, goes off when I restart… sometimes comes on when I start… never had this issue before, was only dropping the kids off at school, the car is high mileage but had no issues with engine or gearbox before… can’t afford a heafty bill right now as lost my business in lockdown and been holding on to my car as I love the stupid thing, got handbrake disengaged at the moment as the gears need rebuilding in the hand brake module which I’ve got the parts few days ago
