Steering Damper?
L
leifwilson
At speeds between 15-50 mph my 2001 DII has a noticeable vibration in the steering wheel. The steering wheel moves a few inches in either direction by itself without any noticeable change in steering direction. Any ideas?
A bad Tire, could be the damper, but normally no. also since you posted in the other thread about noise issues, you could have a bad steering box.....
A
avick
I haven't read the other thread, but tie rod ends or basically anything else under there could be loose. I'd get it checked before something gives up.
D
discoinjapan
Do you do any off roading? Check your bushes, trailing arm and steering.
strally
