Steering Wheel Buttons Acting Strange...
toddjb122
The buttons on the right side of my steering wheel (Mode, Volume Control, Track selection) have had a mind of their own the past couple weeks.
I notice it because I use the volume controls regularly, and sometimes when I hit one of the buttons instead of keying my volume it changes radio source (AUX to FM to AM etc.), or activates the voice recognition prompt.
The behavior will last until I turn the car on/off and then sometimes it stays and sometimes it acts normally.
Just wondering if anyone else has seen this before. ?
Rubber Cow
Its been my experience that electrical gremlins precede battery failure.
How old is your battery?
Toddjb, that has happened to me in the past as well. ....then it stopped doing that just as suddenly and inexplicably as it began.
I don't think this one can be chalked up to a bad battery.
toddjb122
Thanks, guys. Actually, I think both of your replies are applicable!
My battery is on the fritz! It isn't old, but I've been having slow starts every once in a while and the resting battery voltage is low. Taking it in tomorrow.
Or it's gremlins...like Houm had.
CMGRover
Mine does that once in a blue moon. It corrects itself after a few presses though.
Trynian
This is also one of the first signs of the rotary coupler going out. Also known as the clock spring.
kwlr3
Second on the clock spring. I had the same issues, some buttons would occasionally not work and sometimes the note pad would come on all by itself. Eventually the air bag light would come on as soon as the wheel was turned after start up.
toddjb122
What is the clock spring? Any chance that is a relatively cheap fix? (I'm at 143K)
joecool509
It is what allows electricity to go from a stationary object to a moving one. (Steering column to the buttons that rotate without binding or pinching wires
