still having idle problem!!
R
russ00001
my '95 is still ideling at 1500rpms! I have tried everyones suggestions with no luck. Here is what I tried so far
1. cleaned MAF
2. cleaned idle control
3. disconnected battery and left off for twelve hours.
4. new plugs and wires.
5 checked throttle and cruise linkage.
Is there anything else? I'm totally lost, and I'm sure if I take it to the dealer, it will end up costing me a bundle ( just got sunroof fixex for $780!). please help!!!
Sounds like a vacuum leak...
Note sure, I would just look around.. (even check the hose that you found laying on the fender well)
R
russ00001
Fixed!!
Got really desperate and was looking around at out local pick and pull yard and found a LR "Country Estate" with a 3.9. I had never see a single LR in a yard before. I pulled the TPS, idel control and MAF!! Paid $13.00 for all!! I had to change the plug on the TPS because of all things, my LR had a square plug and the one from the yard was round!! I cut the end off of mine and put it on the one from the yard and it FIXED it!!!! I was sooooo excited!!! Thanks for the help! I have learned alot!!
BCNJ
