Sunroof
jonathanrstearn
Just wanted to say hi to everyone.
i have a problem wiht my sunroof. It will not close. I check the fuse, replaced it but no luck. Any advice?
vinnysca
Try this:
Turn key to positon II. Then, hold the sunroof close button for 20 secs. This is supposed to reset/recalibrate the sunroof. If the sunroof starts to close, keep the button pressed for a complete close/open cycle.
Goodluck.
roverman
Hello and welcome to the board. This happened to me once, per the manual try this:
Turn ignition to position II, press and hold front button (close button) for about 20 seconds. Sunroof should start to move and go through it cycle, keep holding button til it stops moving. Then it should work after that. Hope that does it!
jonathanrstearn
Thank You
You are life savers. It was going to be a cold ride skiing tomorrow morning with the roof open. Thanks much, Jonathan, Boston MA
Cpa4S
it is described in the manual as well.
use the same procedure if you find it will not open.
