Super Extended Mode
Trynian
When measured on level ground and unloaded, yes.
http://blog.nextstepdesigns.com/?p=38
Here is a PDF of my measurements:
http://www.nextstepdesigns.com/images/LR3/LR3_heights.pdf
Interesting, both my rear and front wheel wells are at 35.25 in offroad with the same diameter as the nitto terra graplers and the cooper tires.
My tires are only 3/4 inch over stock from the ground so it would be 34.5 for offroad height with stock tires. Maybe it has changed since you did the measurmants and took that picture of Tawfik's LR3 last year.
Anyway it just looked off. Maybe because my wheel arches are higher off the tires with the same diameter tires and your slider outrigging giving the appearance of being lower to the ground.
OffRoving
This question appears on at least three different threads....so I'm putting it on all three of them:
Extended/Super Modes:
http://offroving.com/SuperExtendedMode.pdf
Notice the additional black triangle between the wheels when in Extended mode. There is no further symbol or other indication for Super other than the noticeable increase in height.
MArsel
