Suspension fault help
Mtnrover
Picked up a used 06 LR3 SE a month ago with 75,000mls. when I first got it it raised from access hight to normal hight fine but about after a week the suspension fault light came on saying normal height only, and just a few days ago I bumped the switch and it lowered to access hight and would not raise back up I could hear the compressor kick on then it would shut off. So the next morning i tried raising it again and nothing compressor would kick on then off the fault light would come on. So I turn the rover off and restarted it and tried raising it again this time I got the msg vehicle raising slowly and it raised on my why to work. Then yesterday I got the fault say suspension fault no special programs. But today After I got some new tires put on it raised form access hight to normal hight with no faults coming on. i never get all of them at once every time I start the rover I get one off those three faults
So could it be my compressor going? Or solenoid? air-dyer? or do I need a update on my ECU
Mtnrover
Also if anyone nows a good landrover shop in the Colorado Springs area that would be great
Crunchy When Wet
Mine would only raise, could not lower, and like you said the compressor would start then stop, took it to a private LR shop, they said it was the compressor, bout a new one for $1000ish, installed, no problems since.
Messing around with the old compressor, turns out it still worked but there is a gizmo in there that stopped working, so I installed old compressor under hood with air line, now I can air up my tires after a trail.
Sid1577
