The "Land Rover" 4th Button on the FOB
grommet
The hatch keyfob feature is used on the Range Rover Sport and not intended to be used on the LR3. (That's why it's undocumented.) As you can tell, they didn't disable the programming logic for LR3.
Yep, discussed in this forum ages ago...
toddjb122
The old thread here on that was interesting. Basically, someone figured out a way to open the hatch from the inside using that feature. (on an LR3). Search and ye shall find it!
toddjb122
Thanks for the link, Jack!
Here is the nut at the center of it all... (thanks to grommet)
schafari, I just tried it... it works fine. I can open from the inside. Press once (unlocks main lock), push against the interior hatch and press again (to release the safety, allowing you to push it open). Or something very close to that. You basically have a remote outside button if you program the LR button for the hatch...
MArsel
