Throttle / Pedal Position Sensor
NhudeST
My 04 RR-HSE has been acting up when it comes to the acceleration on the take offs and recently I plugged in my scanner and it gave me these codes: P0120 and P0221. Has anyone else had them come up? If so, what exactly was the problem? I ended up purchasing a brand new throttle position sensor for it and I'm hopping that was my problem. All help possible would be greatly appreciated. Thanks. :bandit:
socalrovershop
yeah sounds like a throttle issue to me. make sure you have no wire damage at the connections and that is connected properly. We didnt really have issue with these throttles. once you replace you will have to reset adaptations.
NhudeST
Disregard this comment.
NhudeST
Will I be able to reset the adaptation myself, if so, how do I do about that? If not, Im under the impression a european certified tech will know all about that? Thanks once again. Ended up having the sensor replaced but now I'm concerned about having it reseted like you said.
socalrovershop
well normally we use t4 to do that to clear the codes and reset adaptations then you leave the key on position 2 for about a min before starting . might find a good scanner you can do that with
rx171
Hi I am ave the same problem, what part did you replace the throttle pedal or the throttle on the engine?
