Tire sizes
discoman
When I bought my Disco the previous owner had left some Bridgestone Duellers that 275/70r16 in size. I find these are way to big. They rub the radius arms at full lock and I havn't articultated the axles yet to see if they rub the inside of the fenders.
I think i will be safe if i go to a 245/75r16. But.......I was thinking of trying the 235/80r16's instead. I like the tall and skinny tires. Is anybody out there using this particular size? Do they rub?
Discovery
* 235/70-16: Stock tire size.
* 205/80-16: Stock size in many other countries. same height as 235/70-16.
* 255/65-16: same height as stock
* 225/75-16: little taller than stock
* 245/70-16: little taller and wider than the stock size. reportedly, no need for lift, just minor trimming to fit those tires.
*245/75-16: popular size for OME suspension lifted vehicles. require slight trimming on the rear wheel well fender, and may also call for adjustment on the steering bumpstops.
* 215/85-16: same height as 245/75-16. but narrower. seems to be preferred for the snow and mud.
* 265/70-16: about as tall as 245/75-16, but wider. will require more trimming and steering bump stops adjustments along with taller bump stops over the rear axle.
* 265/75-16: almost 32" tall. Same as stock NAS D90 tires. Will require even more trimming.
* 235/85-16: same height as 265/75-16 but narrower. And seems to be the most popular size with OME lift.
* 255/85-16: about 33" tall...very few people have fitted this size. Lots of butchering for this one.
* 285/75-16: about 33" also... but very very wide.
Discovery Series II
* 255/65-16: Stock tire size.
* 255/70-16: Just a bit taller than stock.
* 265/75-16: Taller and wider than stock, possible to fit without lift. minor rubbing. Looks real balanced with mild OME lift.
* 285/75-16: even taller than 265/75-16, r requires a bit more lift than the regular OME lift. some have fitted OME751 from Discovery series I, and changed SLS sensor in the rear to achieve almost 3 inches. Gearing and shaft strenght become issues.
* 255/85-16: a bit taller than 285/75-15 but narrower. Gearing and shaft strenght become issues.
Moose
I'll trade you my 235/85's for those Duellers, if they're mud tires :biggrin:
discoman
Sorry. Not mud's. They're more like an AT/Sand tire.
C
cobiker
I've been running Bridgestone Winter Duellers (245/70-16's) on a 96 Disco with no problems... :biggrin: No triming required and they great all year round.
The question is do you off road any? if you do, you will hear it rub sooner or later....
discoman
Since this is the new family wagon, it will see very little time off the road, just the occasional foray a few times a year, nothing too extreme. (extreme is what my Land Cruiser is built for). I think I will go with the 245's since that is the size of my spare tire.
R
rover96
help with tire size
Can I put
ST305/40R22
22 inch 5 lug
I think from the pictures, these are coming off of a Lincoln.
On my 96 range rover. I am not sure what is on there now. I want to buy these tires/wheels but am a girl and think that they will say anything fits. When I call a tire place they won't give me advice unless I am buying from them. I am getting frusterated.
I know of a few people (not personally) that have installed 22 inch rims, but I believe you will have to custom order the rims. Not sure if just any rim will fit on the 96 RR. Either way, that is a lot of money to be spending on rims and tires, but that is just my opinion.
I would call one of the rim places in the back of some of the SUV magazines...
Moose
I am 99% sure that a 96 RR has the same bolt pattern as my 96 Discovery. That means that, unless you are buying 22's from a mid-80's Camaro, there is very little to pick from for wheels beyond Rover wheels.
Why would you want Lincoln wheels on a Rangie, anyway? :biggrin:
PanKyiv
