Turning corners Traction Light and down hill decent light and chime come on?
P
Penguin809
I have a 2000 Disco II 78000, when I turn corners the Traction Light and Down hill light and chime come on. Wondering if it could be a short or something else. Wondering if any one else has had this problem or knows a solution.
Thanks, Tony
C
capthook
Well I know it's those friggin' wheel speed sensors. Run your code for free @ AutoZone & find out which wheel is sending back a bad signal. Everything goes back to normal after you turn it off, then on again right? Sometimes that isn't the case but all and all I'm sure it's your wheel speed sensors.
C
capthook
Penguin809 said:
Thanks I will check that code out.
Right on, let me know what happens with it, I'm having a similar problem and I have not had time to have the code scanned. Last time I had the dealer deal with it, and it was a $800 run so I suggest trying to find the source of the problem yourself if possible
  • joey
Rome0Mike
