Various modules and fault codes, hard shifing
seanfhaynes
The Rover has been shifting hard coming to and from a stop, as well as throwing various fault codes with what seems like every module possible.
Does anyone have any recommendations? I have heard that maybe it might be a bad battery but I do not want to just start throwing parts at it if possible.
the only code that seems like it is legit would be the P0741 Torque Converter Clutch system performance or stuck off. The rest of the codes/faults are "lost communication with .... or voltage out of range or signal invalid
Thanks for any advice
Sean
tlt
Mileage, Year, Engine?
You can start with voltage shut off, and running. If the brake light switch has never been changed, change that, check brake light bulbs as well, though I suspect something else may be going on.
Any service history on the transmission?
seanfhaynes
133k 2007 4.4L v8
We don't have service history from the previous owner, Ill have to swap out the brake light switch and bulbs for good measure. I got a new battery (the original one was still in use but it did not make a difference)
I ended up taking it to the shop as I figure anything trans related I'm not going to be able to do myself :-( still waiting to hear how hard the hit on my wallet will be
