water in spark plug
O
oclee118
Hello,
Can any one help? I have a 1999 disco II with over heat problem. Replaced new water pump and right side engine head. And still find inside of #6 spark plug has water. Exhaust with a lot of white smoke. I’m deeply appreciated if any one can help.
Many thanks,
O.C. Lee
Sounds like maybe a cracked head....
Hudy
Probably has a slipped sleeve in the the block. Common for an overheated engine. You could try a machine shop to fix the sleeve, but it is probably best to find a junkyard engine.
PE_in_UAE
