D
deja7654
I've got a 2000 Discovery II. I recently had to fix a leak on the passenger side and had to work underneath the passenger dash. I removed the blower for the a/c in order to gain access to the leaking area(where the intake tube for the bower meets the firewall). Anyways, it is now put back together and everything works. However, i now have a small issue with the radio lighting on the buttons..When the headlights are off, the lighting is dim and matches the lighting on the a/c controls, but when the headlights are on, the radio display lighting gets bright and the controls for the radio stays dim while the a/c controls and shifter lights get bright green. The radio control button lights do sometimes get bright like the a/c control, but mostly stay dim...If it werent for the occasional flicker from dim to bright green and the fact that its dark outside when it happens, i wouldnt even care..It's just so darn annoying..Any ideas??
