Whirring Noise was broken gear in rear differential
tommy33
Put new rear end in my 97 disco and that fixed the noise. Now the ABS light is on and stays on. Is there a reset or should I check the connections again?
Still have the cdl shifter issue but I will try to put in lock-unlock with a 13mm socket this weekend.
Thanks for all of your valuable tips.
D
discomike
One of the ABS sensors is probably not seated correctly, time to recheck and then have the code reset and clear the light.
Mike J.
Paul p
