Windshield Wipers
P
ParrotheadinALB
Hello all,
Driving home today in a mix of rain and snow, my variable speed function of the wipers died, or at least partially. They would come up, but would take 5-10 seconds to come down. They worked fine in the constant speed mode (both low and high). Just wondering if there 1) there is anything that I can do to get it working correctly again, and 2) is this an indication that my wiper motor is about to go?
Its a 95 Disco, with about 80K on it
Thanks in advance
Jason
Moose
I'd suspect the switch before the motor, because it's working fine at the other speeds.
A
ayavner
I had a similar thing happen on the Honda Civic, and it did indeed turn out to the the switch assembly...
Militant-Grunt
same thing happened with my disco, when the wipers were on INT they'd get stuck, my father screwed around with the arm and they fixed themselves. I would examine the arms carefully to see if there is anything wrong.
Paul p
