Surfrider77
- Joined
- May 17, 2013
- Posts
- 900
- Reaction score
- 127
That's surprising, considering the KO2 are some of the best rated around. In fact, 35" KO2 come stock on the new 2017 and up Raptors!
I would highly recommend you carry a small air pump, even a cheap emergency and compact one will do the job in a pinch. I deflated my spare (285/60R18) to about 10-15 PSI - basically just enough air so the rubber doesn't get deformed down there when I am winching it up or if I hit a rock or something. While that's probably enough pressure to get me limping to some coin-op air down the street, I wouldn't want to be stuck on a highway or in the boonies, miles away from a service station with a flat tire and a half-deflated spare, and no air. Besides, if you plan on off-roading with these tires, you will likely be airing down your running wheels more often than you think, whether it's beach driving or rock crawling. You can easily stash a decent, inexpensive small compressor under the folded 3rd row seats (if you are so equipped) and forget about it until you need it.
