2015 LR4 Brake pad replacement video? Anyone
Davidinseattle
Did you clean and re-lubricate the caliper slider pins?
I checked them. They were like new. There was no grime around it. I did lube the clip tracks. The pins didn't need it. once i bolted the calipers back on I checked the movement by hand. No problem.
Additionally I put the micrometer on the back rotors. One was 20mm and the other was 19.8mm. I couldn't find the specs for min thickness, but the dealer told me they were within spec.
colorover
^ The minimum thickness is stamped on each rotor (for the next time you switch pads.)
jpjp
Florida
Which rotor and pads did you guys go with?
Brake light just came on...
Davidinseattle
used oem pads. rotors were well within tolerances. Easy job. was able to save sensors. bought the brakes from dealer in KC i think. Forgot the name.
Waterndirt
Anybody have spec for front rotor thickness from factory? Trying to gauge how much rotor life ( in miles) I have left, I have 40K miles on stock front rotors. Currently running 27.88 mm thick.
  • joey
