Brakes disconnected???
Casiokorg
Okay you guys, I'm 95% sure it's brake fluid leaking at the wheel from somewhere. I took some towel, cleaned it, put more fluid in. After pumping a bit the exact fluid started coming out from the back, same color, smell and all. What's the next step?
mark D
have someone help you pull the tire off and have your helper pump while you watch see if you can see where the fluid is coming from.
