M
Mark
My windshield leaked and I had the glass people put some sealant on the inside. The technician found the problem and fixed it.
Well, when the next rain came, the driver side was dry, but the passenger side had water on the headliner. It was wet between the glass and the fram AND it was wet up some on the inside of the headliner. I do not think it is the sunroof, because I pulled the headliner/sunroof peice and checked the headliner.
Well I went an put some GE Silicone II along the outside of the windshield where the rubber is pressed in because I saw some areas that looked like the rubber was seperated and may have been a leak path.
I then found some real liquid silicone at Advance Auto and hoped it would soak into the remaining holes and seal. Now I got something else that is supposed to be better than Silicone and is very 'wet' looking. It is called 'Lexel' from Sashco Sealants. It was going to rain today so I did not put any on.
Well it was wet in the exact same place and ran iwth the defrost on to dry it off. Tomorrow will be dry and I will try this stuff.
Does anyone know where this water is coming from? Am I looking in the right place.?
