service engine light on 2003 disco
pjvarc
hi everyone,
recently i changed my oil and filter on my 03 disco.
two days later my service engine light came on and turned off. now this week service engine light came on. any suggestions what could be the issue?
this past spring i replaced the oxygen sensor and abs modulator.
thanks,
p
joey
How many miles, when was the last tune up, what was done during the last tune up and what brand/parts did you buy? What are the codes? Did you have them read? Without codes and more info sadly not much we can do but guess....
I guess the wipers need changed.... (sorry couldn't help myself)
pjvarc
thanks for replying. had my 72 month/ 90k service done in august, no warning lights on prior to service. not due for my 78 month/ 97.5 yet. miles on disco 95k; recently did an oil change and afterward service light came on. prior to 90k service replaced oxygen sensor and abs modulator in the spring.
yeah, replaced wipers except rear, lol. this week rear wiper will be replace.
Disco Mike
Why guess, go to your local parts store and have them read the codes, then get back to us with the fault code numbers. When you had the 90K done did you replace the plug wires and have all 4 02 sensors been replaced?
pjvarc
thanks mike,
replaced the plug wires and had one oxygen sensor replaced. this weekend going to have an EDC to see what fault code numbers are coming up.
thanks again,p
pjvarc
this weekend checked codes and bank one sensor no fault. clear codes.
however was advised may need to replace front 02 sensor.
my question on discos how many miles before its time to replace 02 sensors?
thanks, p
thanks mike,
thanks again,p
joey
What was the actual code you got?
Disco Mike
First thing you need to do is get the exact fault code number not what someone has told you, go get them read again also include your mileage as well as the trucks tune up history as well as plug wire replacement.
pjvarc
i did diagnostic test at the dealer. the dealer rep told me the fault code. i keep i need to invest on diagnostic tool to read the fault codes.
mileage on my 2003 disco 95,200
i'm the second owner.
tune-up history since my ownership:
did 75k maintenance
did 90k maintenance
replace value gaskets
02 sensor replaced at 81k
replace abs shuttle valve
prior history previous owner replace plug wires at dealer and all schedule maintenance was done at dealer.
PE_in_UAE
