Not gonna lock up unless it needs to....and it's easiest to do that in Rock Crawl Mode with some torque required.
Is there a full-sized spare under it?
Silmarillion
There is. I called LR corporate and they said the VIN didn't show it had the HD package. The dealer and the mechanic I took it to said it did have the HD package. I'll keep my fingers crossed that it does.
...well if the little motor is on top of the rear diff that's another tell-tale sign.
rovernut
Try topix.landrover.jlrext.com and plug the VIN in there.....
grimmecm
06 SE V8. johnson rods. 275/65/18 Atturo Trail Blade MT.
morrisdl
De-tango'd, amber LED bulbs, 80W LED H11 fog lamps, 80W LED OFFroad H1 lamps, DRL controller, (4) COB LED rings 100mm, and (2) 80mm Rings for the fogs lamps.
All the lights finally match in color temperature.
BCNJ
