rough idle engine after reaching operating temperature
z1234567890
rough idle on LR4 v8 after engine warm​
Hi Everyone
LR4 2010v8 5.0L petrol engine owner here, I have situation with my engine, where after engine reach operating temperature/warm, it's showing a rough idle, the sympton is described in this video
1. RPM up and down
2. The engine bay has noise as per video
Action point already taken but does not help
1. Clean MAF sensor both left and right
2. Clean air filter
Do I missed something here? Kindly share your knowledge if you have ever face same problem
z1234567890
I just replace the passenger side valve cover gasket, might be its not proper fit and causing a vacuum leakage?
gsxr
Big Sky Country
Just to clarify. The engine was running normally before you changed the passenger side valve cover gasket... and afterwards, you had the rough idle and surging RPM's?
