just clarification here
FloridaLR3
So I have a 2006 lr3 se and to my understanding if you have a whining or humming noise or what i like to call almost like a warped rotor sound coming from rear . I can only hear it when Windows are up. So to clarify if I am driving and switch the gear selector to neutral at say 50mph and the noise is still there it's safe to say rear diff is on its way out? I was reading up on a forum in here about it but no one answered that conclusively.
Sent from my SM-N920V using Tapatalk
tlt
Typically it would expect that you should check all your wheel bearings, and then check the rear diff. I'd guess it's the diff. Could also be a few other things but that's going to be the common ones. Let me know if I can help once you sort it out.
FloridaLR3
thanks I'll get it up on a lift tomorrow and have a look. if I get play in rear wheels moving up and down or side to side it's a wheel bearing yes? I'll send you an email shortly
howardduff
Cleveland, Ohio
I lost the front wheel bearings on my 07 LR3. There was noticeable shake when the car was jacked up. Not a real bad job but the torque for the axle nut if I remember correctly is 225 ft. lbs. Took a long bar to break it loose and the bearing had a bunch of rust on the outside race making for a lot of hammering to get it out but it went together great and was quite when I sold the vehicle. Good luck.
FloridaLR3
tlt thanks a lot. I bought all the fluids and installed them today. What a difference! Royal purple is what I use in my audi and never thought to put in my landrover. I can tell a huge difference and believe it or not the whining noise has dropped dramatically. I'm impressed! Everything done but get the filter and zf 6 fluid for the trans. By the way I tried to call your number today .
FloridaLR3
The bearings have been replaced in the front recently by a shop. I've yet to source a good company on rear . The fronts I bought were supposed to be the rears so shop said well your fronts are bad, so I had them do it. Been to busy to buy the rears. I forgot to check movement on it while on rack.
Johnathon65846
