Wet Driver floorboard 2011 LR4
Jermgallo
Lowell,ar
Last night we had a massive rain storm and this morning I had water standing in the floorboard on the driver side. Any ideas or suggestions on this issue would be helpful. This is the first time this has happened and it has been out in other rain storms before with no issue.
Troy A
San Francisco, CA
There are many posts about this in the forum. https://www.landroverworld.org/search/14351513/?q=rain+water+leak&o=date
rfh1987
Happened to me in my LR3, a few years ago. Basically, the drain for the moonroof is clogged.
Sent from my SM-G955U using Tapatalk
pop sunroof, remove interior A-column trim.
You will see some drain holes towards the outside forward edges of the sunroof. From the inside, you will see some plastic tubing and connectors that connect to these holes.
You need to get those unclogged. LOW pressure compressed air works fairly well. When you get them clear, you should be able to apply water to the drain opening in the sunroof and watch the water hit the ground roughly from behind the front fender air intakes on both sides.
Jermgallo
Lowell,ar
Awesome, thank you so much for the info. I’ll get on this today.
steveC101
It may also be the drain tube exit plug under the dash. Easy repair.
John Robison
Springfield MA, USA
To add to what has been suggested, which is good . . .
- The plastic drain tubes can clog with pollen and if you try and blow them out with compressed air you can blow the tubes loose in the pillar. That is why the suggestion for low air pressure. You can also use a 5-foot length of mechanics wire with a loop on the end
- In salty climates I have seen the metal parts of the drain tubes rot out, necessitating more extensive repair
- Rain water runs down the windshield and into trays on the firewall. The trays have drains called cowl drains, to drop the water on the ground. Those can clog with leaf debris and cause water to back up into the car. Clogged cowl drains are a major source of interior electrical damage in the northeast US
Bethesda, Maryland, USA
Still watertight at 7 yrs and counting and doubly grateful for garage storage...not that there are any guarantees with a Land Rover. But we love them just the same.
DaytonaRS7
now that i know about this, im gonna blow out my sunroof drain tube today. 5 minutes of work could prevent a gross mold problem.
140k miles in the northeast makes me feel that it may need it.
Izanagi
