- Joined
- Jan 6, 2006
- Posts
- 3,938
- Reaction score
- 256
...that's a bummer.
yes display works but there is no way to "T" off the optical cable from the new wiring harness for the radio so it just displays Land Rover screen as shown...I'll probably just take it out and put in the standard cubby if I can find on or mount up an ipad for some dedicated gia mapping etc...haven't decided quite yet.
I am not so certain that you are beat re the Off Road display.
I understand that you had to disconnect the fibre optic cable when the new "radio" head went in. I also think the brains of the optic system are in the Head unit but jumping the open fibre optic pair is worth a try.
Per the link below, one can get a "jumper" (looping tool) the joins the open ended part of the orange optical cable. The jumper allows the red light to keep going in circles assuming there is red light to circulate. I guess if the red light died when you disconnected the head unit you are beat but if the cable remains alive, there is a chance the nav unit might still display something other than the default logo.
Alternatively, if you still had the head unit and could power it up plus found a place to stuff it so to speak so it remains but is hidden in the system .....
https://www.disco3.co.uk/gallery/displayimage.php?album=34462&pos=14
Link to a number of files in the Nav / Radio album including wiring diagrams.
https://www.disco3.co.uk/gallery/thumbnails.php?album=34462
If there is still red light coming out of the disconnected cable ends, or at least one of the cable ends, then there is hope.Thanks for that info...it's certainly worth a shot and see what can / can't be displayed by looping that line...some use may be better than nothing...I do still have the head unit but I'm not sure where I could hide it but at a minimum I'm definately going to try to loop that optical cable.
I am surprised, amazed really, that even if you had a proper loop, that it would work. That BIC pen internals can substitute for fibre optics is even more impressive.I looped the fiber optic cable with a 2" piece of a bic pen and some electrical tape. I don't have factory nav though but everything else functions as it did before I took out the factory amp and radio. I did a write up, you can search for it and it may help.
Attached are a LR pdf explaining the Nav system and the other is a pdf explaining the Audio system.Yes, that is my thread. I'm not sure the color of the light circulating but I have full functionality of all components. I removed the factory amp and looped there and removed the factory radio and looped there. Again I didn't have factory navigation so if there was functionality there I had nothing to lose.
