2011 Disco 4/LR4 catalytic converter fail
Which one would you go?
  • New genuine
    Votes: 2 25.0%
  • New aftermarket
    Votes: 5 62.5%
  • Used genuine
    Votes: 1 12.5%
  • Total voters
Big Sky Country
Lets start at the beginning. Who said your cat needed replacing?
Ditto this: ^^^
Generally, factory cats are far superior to aftermarket (there's a reason the aftermarket are so "affordable"). However in USA, federal law prohibits sale of used catalytic converters. So you won't find any salvage yards in USA selling them. Only possibility would be a private party sale. Not sure about Canadian laws.
ar077
Las Vegas, NV
Ditto this: ^^^
"...far superior..." in what aspect of performance? The only considerations that matter in a replacement catalytic converter are 1) is it less exhaust restrictive than stock?, 2) is it cheaper than stock?, and 3) is it legal? Nobody cares about anything else.
Big Sky Country
OE is typically superior in longevity and reduced emissions, not power output.
While I can't comment on LR4 cats specifically, for some other marques, replacing a cheap converter every few years ends up being more expensive than buying a good one up front.
I still want to see an answer to ktm's question about why the cats supposedly need replacement. There are some LR4's on this forum with 150-200kmi and no reports of dead catalysts, that I know of.
o_O
Joel123
Winnipeg Canada
Looking for recommendation guys, things are my 2011 Disco 4 cat converter need to be replaced so options are:
1) Genuine parts ($3k/ea)
2) Used ones: I found used parts from 2006 Disco 3 which $500/ea so would they fit mine?
Anyone had same model available just let me know. I’m in Calgary, Alberta, Canada. Thanks a lot for your helps
Hey, I've been driving on a engine code for the passenger cat for some time, dealer price is over the top. I have been watching Parts Avatar for the Direct Fit Cat by Davico at $650. Did you have success finding a replacement? I am in Winnipeg
Bushwa
Calgary, ALBERTA
Have you considered this. If you’re getting a CeL for cat efficiency below threshold, they may be operating at 89% efficiency, while the lower limit is 90. mine started throwing a code for this at about 280,000 km. No way I’m dumping thousands into cats for a vehicle that’s now worth peanuts due to a dodgy reliability record and high mileage. I installed 1/2” spacers on the o2 sensors. CEL gone.
Bushwa
Calgary, ALBERTA
It's just a threaded extension, unplug and unscrew O2 sensor, thread the male end into the pipe, reinstall O2 sensor into the extension. It spaces the tip slightly out of the exhaust flow so it generally reads lower. You'll occasionally throw a code for "O2 Sensor Heater slow to warm up" but it doesn't trigger a CEL in my case. Most likely illegal in most states and provinces, so proceed at your own risk. Is it any more harmful than just ignoring the CEL and driving it?
Joel123
Winnipeg Canada
How would I find out what efficiency the cat is running at, or is that even important? Also I thought a cat code means lower fuel efficiency, would it improve with a new cat? ....and 3 where would I get the threaded extension for the 02 sensor?
Big Sky Country
Cats won't affect fuel consumption unless they are plugged enough to reduce power/airflow, which would be pretty rare IMO.
I would be very curious to have someone weld up a set of straight pipers with a b u n g on each end for the sensors and see if the truck had any problem with that.
I may or may not know a bunch of 911 guys who have run that configuration with zero ill effects. And yes, I know they are supposed to sense differential pressure and all that. Just saying that it might or might not work in the Porsche world.
ETA: God, this auto censor is getting touchy.
