07 Range Rover sport SC electrical issues..
Stoody55
Brooklyn, NY
Was picking up my kid from school yesterday, the car was driving fine but all of the sudden the battery light went on then the suspension’s, transmission’s and some other light that looks like a hot cup of coffe lol (sorry I’m not too good with those things). And if that wasn’t enough half way home everything electrical shutdown in the car no dashboard no radio etc… only the car was running, when I got home and I turned it off and tried to turn it back on again, it wouldn’t start. So, I gave it a couple of hours and tried again and it worked but I’m just a lil concerned if that happened to me again while driving on the highway. Please help!!
joey
Have your battery checked. Sounds to me like it is time to replace it.
crImdoc
1. Check battery with battery tester and make sure the terminals are tight and clean.
2. Make sure alternator is outputting 14 volts... anything less is a problem.
3. Ensure you have a good ground (grounding-strap passenger side of engine to subframe , if loose, will cause all kinds of problems)
4. Put it on a diagnostic machine.
In that order. Good luck!
d
