Troubleshooting coolant vacuum fill failure
greiswig
SW Washington
What I remember from doing my own procedure was that the hose with the thermostat is amazingly complex and hard to reach to work on it in situ. If I hadn’t first pressure tested the system, I would not have found that one of the clamps I had put on wasn’t seated properly. Vacuum fill wouldn’t have found that, either.
Land Rover Joe
@Rendak,
As folks mentioned - these problems with the coolant system are rather legion with the LR4 (at least the AJ 133 engine I have in my 2010)...and coolant problems appear to be multiplying with newer engine designs (for all vehicles).
It seems engine designs are getting more and more complicated and integrated which puts more stress and strain on all these cooling system parts - causing them to fail. Combined with using all kinds of plastic and rubber parts...that makes these things relatively "unreliable" (i.e. they brake, sometimes at the worst possible times) and something to keep our eyes on. As I noted - I have had quite a few troubles with my cooling system but fortunately nothing catastrophic.
Also, making mistakes is all part of "the adventure" and happens to everyone. So if the hose disconnected for whatever reason, know you are not the only, the first, and certainly won't be the last. It happens to the best of us and here is a pretty funny video of Christian and Vera (from their very popular YouTube Channel LR Time) heading into the Alps for a big test drive of Vera's DISCO 3 after a total rebuild (but not total replacement)...only to have the thing almost overheat because Christian screwed up and forgot to close off a coolant hose clamp- which dumped out all the coolant as they were climbing. Pretty funny (as a learning point) and good news because no one was hurt and the engine was fine - they caught the issue in time.
Just to prove that these things happen - we will see you on the high ground!
Rendak
Atlanta
Thanks for the kind words, @Land Rover Joe! From one internet stranger to another, I really do appreciate it. :) And I love LR Time! I haven’t seen this one, but it makes me feel better to know that even Christian makes mistakes.
I’m taking some time away from the LR4 this weekend, but when I get back to it on Tuesday, I’m gonna redo the vacuum fill and pressure test and then start some diagnostics for any signs of overheating. I’m hopeful that because I didn’t get any DTCs at all and because I pulled over and shut off the engine within about 10 seconds from noticing the engine going into limp mode that I didn’t cook the engine. Keep your fingers crossed for me!
Land Rover Joe
Thanks, take your time, and keep us Posted @Rendak !
I will keep my fingers crossed!
As for my build (or extensive service is more appropriate)...engine was buttoned up today and tried to turn it over....only to have continual faults from the brake system which in-turn (I think) shut the whole computer down. So we could manually run the (new) starter motor and charge up the fuel system with the HPFP (by overriding them on the relay board)...we couldn't actually get the engine to run.
I am waiting for two more pistons for my front calipers before finishing the front brake installation / refurb and so the brake system is currently emptied out and there is no pressure anywhere (and the brake lines haven't yet been fully fitted). So the computer must be detecting a major brake malfunction (True!) when going through start-up ("Press the Brake Pedal to Start") and just conking out.
Guess we will have to finish with the brakes first...which gives us the chance to continue cleaning up, painting some corroded parts, and redoing wiring looms.
Good luck again and wish us luck with the next phase (starting engine - hopefully next weekend)!
CPalacay
Woodinville, WA
Having just completed the timing chains, along with replacing the front and rear cross over pipes, water pump, thermostat, radiator and every coolant hose in the engine bay, I can empathize with your situation.
Mine failed the vacuum test and I couldn’t understand why after checking all the connections multiple times. I ended up picking this up and was able to find the cause in a matter of seconds of running it. It also gave me a good reason to upgrade to the brass fitting for the water pump.
Solary Automotive Smoke Machine Leak Detector - https://a.co/d/6zoYOS6
Good luck!
ttforcefed
Mine failed the vacuum test and I couldn’t understand why after checking all the connections multiple times. I ended up picking this up and was able to fine the cause in a matter of seconds of running it. It also gave me a good reason to upgrade to the brass fitting for the water pump.
Good luck!
Curious what did you pay for all that work?
Rendak
Atlanta
Today I got back under the car and connected the radiator hose properly but got another vacuum leak so I put in close to 8 liters of coolant and then hooked up the pressure tester, but this time I am struggling to generate even a few PSI of pressure. No external leaks that I can see either (and no drips or pooling under the car), so like before, I'm worried that the worst has happened and the head gasket is blown. I'm gonna go by Harbor Freight tomorrow and pick up a combustion leak detector kit.
If it turns out that exhaust gases are entering the coolant system, does it make sense to pull the spark plugs and run a borescope to see if coolant is entering the combustion chamber? And are head gasket repairs even worth it on these engines, or am I looking at potentially getting a remanufactured engine?
Really sorry you are having this string of bad luck. Hope things start looking up for you.
Not sure you should run the engine for the exhaust gas test with only 8 liters of coolant in the system (and a massive leak someplace). I’d probably do a compression or leak down test on each cylinder instead.
I suppose the other thing you could try first is running your pressure tester on the coolant system while snooping around with a stethoscope with the cone on it to listen for the hissing of an air leak. If you have a compressor with a large enough reservoir, you can probably get a few minutes of quiet air pressure before the compressor kicks on and makes it hard to hear the leak. If your leak is into a cylinder, you might hear it through the plug hole, but first I’d just try listing around all the coolant pipes.
No idea if it’s worth doing the heads if that’s the problem. I remember reading a mechanic’s post one time saying that the head bolts have a tendency to either strip or get loose after the heads are replaced, resulting in recurrent head gasket problems, so that this persons’ garage wouldn’t even do them anymore (people would return blaming the garage for shoddy work). And, maybe as a result, it seems like people charge really high prices for the work, so it’s a tough question whether it’s worth it.
Rendak
Atlanta
I think before I do any of that, I’m gonna throw a Hail Mary here and see if the expansion tank isn’t the problem. It’s never been replaced, and it’s not wildly unlikely that a 10 year old piece of plastic exposed to countless heat cycles + the potential heat and pressure stress from last week’s adventure on the highway could cause it to warp around the neck, causing both vacuum and pressure tester tools to get a poor seal. So I think I’ll get another expansion tank online and then if that doesn’t solve the problem, I’ll get the truck towed to reputable local indy JLR shop and have them do the engine diagnostics.
Finally, thank you for the kind words and well wishes. This has all certainly felt like a gut punch, but I have to remind myself that over the long haul, even a $10k+ repair on a vehicle that I got for $15k isn’t going to break the bank, nor will it be something I have regrets about when I’m laying on my death bed 50 years from now, lol.
Land Rover Joe
@ Rendak - what is the service history of your vehicle?
In other words, How many miles do you have, are you the first owner (who owned previously), what has been done with the engine and cooling system already, how often do you change the oil, what kind of fuel is used, etc?
Those details are going to be important in figuring this out.
I can tell you that the fluids changing business is super important. I have been pretty fastidious with my oil changes (around 5,000 miles or one year between changes) and in going over the engine after my recent tear down (still a work in progress)...my OCD must have made a huge difference. I have 90,000 miles (some tough) and 15 years of wear on that engine and things inside looked great - no issues and no issues even developing. But...There are a lot of folks who don't change fluids (particularly engine oil and transmission fluid/oil) and wreck things. In fact, Land Rover said that we were supposed to change the oil every 15,000 miles with the V8 (AJ133) I have...which is completely ridiculous and insane. There are a million spots in that engine where gunk can block oil passages and whatnot which will destroy the engine and can easily cause problems with the heads which could cause symptoms like yours.
So to put it simply - if you are at a fairly low mileage (less than 150,000 miles) and have been good to the engine, then I would guess that this could be tricky or strange...but totally doable. If, on the other hand, the engine has not been well maintained, then this could easily be the head gaskets or something else similar regardless of mileage which will be ugly. As I am sure you know, these aluminum engines can warp easily from heat and those heads, and potentially the block, could be way out of tolerance if warped. That situation would indeed require a new (or reman'd) engine (Yikes).
I doubt it is the expansion tank and from your description this sounds like something more complex, potentially very bad.
tragic1
