Update to this thread: I contacted GAP about the fuel pump duty cycle and they suggested updating the tool. It worked and we now have fuel pump duty cycle readings. We also seem to have gotten pressure readings for the low pressure side of the fuel system, and some other things I haven’t explored yet.
It looks like the updated GAP firmware now identifies the engine type and tailors the codes to that engine so (hopefully) it won’t keep showing fields that don’t apply, and will show more fields that do apply. I haven’t played with it much yet, so not completely sure what else has changed. But it looks like a good update for SCV6 owners.
Couple of things - if you haven’t updated the tool before, you need to follow the directions in the manual completely - update the tool then, leaving the tool attached to the computer, use your BT device (phone or tablet) to connect to the tool and update the software in the device app. My updater shut down prematurely once and I thought it was complete, but then seeing the instructions I ran it again and it completed the process.
The other thing I noticed was that, when I went to look at live values after the update, if I tried to use my saved live values, the app would quit (iPhone app). But it allowed me to select from the complete list. I think some of my saved values are probably no longer available and trying to open that window caused it to crash, so you might need to just recreate any saved categories.
