CONCH
2015 LR4 SCV6 (GAS) --- If anyone has replaced the #1 Right Bank O2 sensor, does this one look correct? If you zoom in, it appears that the wire (white section) on this one may have been cut and then patched back together. Having an issue with code P0420-00 (Catalytic below efficiency). Only happens if I go highway speeds, so trying to look at other possibilities before a CAT replacement.
Has anyone replaced the right CAT in the drive/garage at home? Wondering how accessible the top bolt at the exhaust manifold is from under there. Doesn't look like it is readily accessible.
