My front coolant pipes and water pump were replaced by the previous owner 3 years and 30,000 miles ago. There are no leaks. I recently replaced the main radiator, which had a small leak and replaced all the coolant hoses, thermostat as well as both belts and tensioners and the fan.
What I discovered from this adventure is it's better to use OEM parts. I bought a few aftermarket hoses, but some didn't quite fit properly. The fan is after market and it's fine.
After doing this work, I discovered, using an endoscope camera, that the rear Heat Manifold (rear crossover) pipe was leaking. I looked at numerous videos and online forums showing how others removed the supercharger but, in these instances, they were replacing the front cross over pipes as well.
I didn't need to change those pipes or the water pump, so I decided to attempt changing the rear pipe without removing the supercharger. Something that is ill advised.
My first concern was there enough room to get my hands back there and would the wrenches etc. fit. My next concern was were the torx screws holding the pipe seized. Using the camera pictures, I was able to see the torx screws that hold the pipe. I was able to get a torx bit and ratchet on two screws to see if I could loosen them. This worked!
I've begun removing the backets holding the engine cover and the bracket that holds the wire loom channel at the back of the engine and freeing up the wire loom by removing the plastic cover and clipping some tie wraps.
I setup my iPhone to record my work to help me when I reassemble everything but also if this works, to post my adventure.
I found a document that describes this procedure for a V8, naturally aspirated and supercharged.
Any suggestions are welcome. I will post my progress, or failure.
