Since acquiring this mechanical marvel
I completed the following repairs/updates:
1. Replace main radiator, thermostat, all coolant hoses, flushed coolant, new fan.
2. Replaced both belts.
3. Replaced power steering hoses, the metal fittings were rusted but not leaking.
4. Replaced heater manifold pipe (rear cross over pipe) with aluminum version. The old one was leaking. Front plastic pipes had already been replaced.
5. Replaced both front cameras, blind spot sensor.
6. Replaced front air struts. They were not leaking but original to the vehicle.
7. 4 new tires. The Pirellis were 2021 with only 25,000 miles and plenty of tread but had cracking between the treads.
There are no oil leaks visible on the vehicle.
The only issue is I find the ride hard when going over road bumps. The lower control arm bushings appear to be the poly versions which I suspect may be the reason it rides hard.
Timing chains have never been replaced but there doesn't seem to be excessive noise from the engine.
No errors codes related to the engine, suspension.
I was thinking of replacing the lower control arms with OEM to address the ride harshness.
Any suggestions for preventive maintenance? My tools are getting lonely.
