Cargo Cover
Bokbfok
Tucson
Do you have an STL file you can share?
I have only test fitted it. No driving testing but is seems snug.
Here you go. Well, maybe.
I had to change the file extension to one of the acceptable(PDF) types. Change it back to STL and if that doesn't work, I can DM you.
  • Cargo cover piece.pdf
powershift
Nevada
I'm curious about that file encoding even though I don't have a 3D printer. If you were to rename it to .stl it would be compatible with a 3D a printer?
Bokbfok
Tucson
The .STL file is for the slicer. The slicer will convert to G-code and that is what the printer will need.
That is a broad brush ****** of an explanation
